Over on a blog site called Brickhamster, there is a continually growing archive called "Modular buildings building guide" with pictures aplenty. You can check out just the images over on the Flickr account. So far it covers the basics to modular house building well as some nice tips & tricks.
Good stuff!
24 Hour Carrot Shop?
I like it.
Some of his designs are outside the usual so I like them too. This one is part of his Chinatown 2035 series and meant to be a type of futuristic urban farm looking somewhat made from prefabricated 3D printed construction components like the roof.
Of course. That was my second guess
