like it a lot but looks expensive if bricklinked
For those who have been following this topic for a while may remember there was a general "How to" guide in the main post. Well the last forum conversion seemed to have lost the data and images from that leaving a couple sentences cutoff and a lot of empty space. Anyway I finally managed to fix up that guide with the correct pictures and such so anyone in need of some help getting started with their own modular house, hopefully the brief guide will give a good start in the right direction.
Funny I found this because I was just thinking the other day what would the Cafe Corner look like in a different color or (jokingly) perhaps as a Friends set? Well, whatever the reason, enjoy the 'pinkitude' and cuteness of the "Lovely Hotel". :biggrin:
Here is the page on LegoGenre for this special MOC.
The builder's original page and brickshelf gallery.
Revisiting the first page I saw this awesome MOC that combines LEGO friends with modulars...
Having been to Japan recenty together with the sign "HOTEL" this makes me think of a love hotel ^.^
so this truly is amazing! but I'd say that this is the wrong thread for it as it in no way is a modular (and inspiration could be anything...)
we have an architecture thread though don't we? I think putting this there would be a better idea, not just because it belongs there but also to "push" the thread up a little bit again.
