That Palace cinema combo is making me drool.. Looks very nice.  But for now it stays in the box.
So there is a HH right behind PC?
That's just two PCs combined, right? I'm not seeing any extra pieces for the exterior.
It is, but it's a mod as well using two sets. I found a better image earlier, taken from a different angle, but I cant find it now.
Something like this
Yeah just twp PC's.
There was a description, but I cant find the page I was on.
He built the first one mirrored without the side wall, then built the other..
found it
The modular modification to the Haunted House is very good. The original design could fit in before being a large-scale building but the 'dollhouse' setup in a street of modularized homes made it stick out more than the fearful facade did. Here the structure goes seamlessly with the rest of them on the street without really altering what the abandoned abode is all about. If anything this is like an answer to the "What if LEGO had released the Haunted House as a modular house?" question.
On one hand, I know I would like to make the same changes to my own Haunted House yet at the same time don't because of all the sets I have owned this is that perfect one I just love to have on display all year round.
Yeah I agree, fits so well as a modular. I cant bring myself to open a new haunted house though, so will probably never be able to build it. Would love to find instructions, and brick link the extra parts. Like you, I'd like to display this all year with other modulars
They do, scroll down the listing.
never to early to start think about xmas
Gingerbread House1
Edited by brickcrazyhouse
I am currently building the PS, finished apartment side.  I noticed that LEGO changed the fencing piece in the front.  Anyone else notice this?  The piece in the set is now slightly different than the one in the photo.
HH needs a big hill at the end of the street...
though it would be intresting to build some burned out row homes (http://s179.photobucket.com/user/dtoronto/media/Philadelphia15.jpg.html
I mean what legit city does not have some?
What are people's thoughts on the Mocs without stairs between floors. It does make it a lot easier and free up some more space but does take anything away. When designing on ldd I always put stairs
For a change of pace, here by the lovely Kristel is a modular conversion review on the Kwik-E-Mart. While she does go over the main model including bag contents (good resource for that other topic), the main focus here are the different attempts made of turning the official set into a modular style house using only the parts featured (with the exception of two 1x2 Technic bricks). You won't find direct instructions on how to build any specifically though but I believe these make some great inspirations.
An alternative could be a simple ladder from one floor to the other. I know a handful of people who do not bother with furnishing the inside of a home if it is merely for display and/or you cannot see into the place all that well anyway but it feels odd to me having a house not filled in (unless it is meant to be abandoned or a rental property waiting for a tenant). Plus I enjoy the challenge each gives. I mean it was difficult but I did manage to come up with a two floor 'spite house' out of three Small Cottages which took all of a 8x16 space and it has a row of stairs.
There also is the revolving staircase that uses little room you see in a number of the official modular house sets.
