For anyone following, this topic was originally the "How to build a modular house" with a very nicely detailed walkthrough I had found over at Eurobricks to share here because I felt it was a fantastic resource in aiding anyone who ever wanted to make their own. Well I was thinking lately and the short of it, I wanted to help bring some better usage for this thread therefore I modified it a tad allowing the inclusion of displaying all the different sorts of custom modular house projects one may find across the net in the same manner how the MOC Highlights topic is for all general designs and MOC Alternates is for alternate builds. That way you had a basic guide to start with well as a number of projects to help give some inspiration hence the title change. (You may have noticed the MOC Highlights topic has shrunk a little which is because I moved any modular house design from over there to here.)
Please feel free to post anything fitting within the Cafe Corner standard (32x32), Market Street standard (16x32), or even the 'spite house' standard (8x32). You can still find the How To guide in the main post to peruse. To help kick off the update, here is a double whammy with two stables of delectable desserts in a Krispy Kreme beside a Baskin Robbins.
Baskin Robbins and Krispy Kreme.>Baskin Robbins and Krispy Kreme by tehLEGOman
Here is a selection of Super Hero themed modular buildings particularly based on actual sets designed by Hay Core. Oh and a Toys R Us just because.
http://www.flickr.com/photos/87160724@N06/sets/72157633143559829/
http://www.flickr.com/photos/87160724@N06/sets/72157633843060814/
http://www.flickr.com/photos/87160724@N06/sets/72157633863123491/
http://www.flickr.com/photos/87160724@N06/sets/72157641233127174/
http://www.flickr.com/photos/87160724@N06/sets/72157644182749360/
http://www.flickr.com/photos/87160724@N06/sets/72157634104569861/
the guy could have done himself a favor to make sure everything was pressed together well. Those unnecessary gaps are just hard to look at.
These gaps ruin everything.
6928059157_5e9b8b5b9c_b.jpgEmerald House by cimddwc
Indeed. I almost didn't post that set because of the messy bits but still I thought some of the overall ideas for aesthetics in the buildings were good albeit difficult to see past the obvious downfalls. At best there should be some decent inspiration to be had and maybe even a little nod towards what not to do.
Here is a collection of 'mundane' builds to help add some realism to your city.
http://www.flickr.com/photos/vkessels/sets/72157637884137544/
Building Site by Mr. Tomato Bread
http://www.flickr.com/photos/vkessels/sets/72157646930599598/
Sewage Pumping Station by Mr. Tomato Bread, on Flickr
http://www.flickr.com/photos/vkessels/sets/72157633051906129/
Telephone Corner by Mr. Tomato Bread
http://www.flickr.com/photos/vkessels/sets/72157633055941680/
Gravel Path by Mr. Tomato Bread
http://www.flickr.com/photos/vkessels/sets/72157629167885263/
Modular Recycling Lot by Mr. Tomato Bread
http://www.flickr.com/photos/vkessels/sets/72157627393168340/
Gate House by Mr. Tomato Bread
