Maybe, from now on (I mean after this set has been released in the IDEAS line and LEGO continues it with a new whole underground theme), people will not only make their guesses what Modular will be released in January each year, but also which variant of a basement attachment will come next ...
Edited by Frank Brickowski
trying this again
Edited by Donut
