7s3476igyyn51.jpg?width=960&crop=smart&auto=webp&s=bef045529ed434c753d01d2065a7e7874d401da5
kuw954igyyn51.jpg?width=640&crop=smart&auto=webp&s=efa3518081f04dea4bc0087023f2664d01808570
I would think the market for something like this is small. I think most people just build and forget.
Putting something under a modular is a process. One way would be to modify the build it sits on to accept a baseplate. It obviously can’t connect without something to interface to what’s on the baseplate.
The second would be to take the baseplate out of the equation. Start the build on a plate and go from there.
You actually do connect the Basement only by putting 3 to 4 clips onto the edges of the Modular's Baseplate, after removing/replacing the tiles there. This should take about 20 seconds - that's a rather short "process":
Edited by Frank Brickowski
apologies if this is in the wrong thread (please re-direct if so!) but was wondering if anyone here can recommend a freelancer that could take a (real) home design and design lego instructions based on it?
