Finally finished my Haunted House custom modular.  Don't mind the random color plates and bricks inside...
^ That is beautiful!   I spot lots of creative use of pieces for styling.  I also feel there's a nice balance of detailing that doesn't overwhelm as it's a smaller sized model.  Very nice!
