On ‎1‎/‎12‎/‎2014 at 11:13 PM, TheOrcKing said:
For anyone wishing to turn the Palace Cinema into a straight section should check this MOD out.
Any idea if this can be done only with the original set itself?
22 hours ago, calmdahn said:
Wow. What do you use to get your tiles so straight!?
A lot of time and patience I would imagine. Haha.
The builder states they used the original set with an assortment of additional pieces (rough guess around 600). Anyway it seems the old link for that Palace Cinema mod was no longer working properly so I corrected it with this updated one here.
I've been following this topic since a while and thought about registering today to say you how much I appreciate your effort! I'm already a Eurobricks member and have been running a similar thread over there and this topic definitely helped me to find modulars! Thanks so much! ?
Central Station by bricksandtiles
I am glad to hear it and thank you. There is a plethora of amazing builds in your topic; some familiar, others new, all very good.
