  • Views 659k
8 minutes ago, Elkkthunder said:
anyone have these instructions they would sell
https://modularsbykristel.com/blooming-blossoms/
I bought a collection that has all the parts but no instructions and no longer being sold online that I can find
Did you try and send a message to Kristel they are still active.
I did. She says she is out of selling instructions. Her bricklink store is closed, ebay link nothing and if you read recent posts on her blog.
Its a bummer as my estate sale purchase has all the pieces just no instructions. I messaged her but she said she cant help.
I was hoping someone had them and I could purchase
She can't even send you the digital file?
If she can't even help with that, try posting to Reddit and telling them the story. Or probably even EB. That might be better. I'm sure there's already a thread about the build over there.
there is on EB, not commented on for a long time. I will try reddit
I would try both, and just mention that the original author isn't able to help anymore.
Speaking of old modulars- does anyone have instructions to the record store?
Exact same problem as elk. All the pieces nicely shrink wrapped, but no instructions.
Contacted brickbuilders and they are not producing instructions or the stickers.
Here Lago pulls double duty with his modular re-imagining of the classic 6350 "Pizza To Go" set from 1994.
Pizzeria by L@go
That is amazing.
Saw that the other day on YouTube. Absolutely stunning.
On ‎6‎/‎14‎/‎2017 at 10:39 PM, TheOrcKing said:
I don't understand if the guy walking the dog is supposed to be on the ground. Why?
It looks to me the Husky is walking the kid.
