  • Views 659k
On November 26, 2016 at 1:37 PM, brickcrazyhouse said:
These are such great ideas! Has anyone here built a train track under a city like these? I might have to start planning something out, very cool!
I have to agree. This is my favorite build so far. Make sense space wise as we all don't have that extra room or basement for a large city. I have something similar using small plywood pieces for the base elevating our town to a harbor below. However looking at this, placing a train below just looks too cool. Will be trying that soon.
please post some pics of your set up, some time.  even if its a work in process, it will help out others. I know i would appreciate it
Awesome. I think I see my lego self at the bar
Won't be long before that company steal the design & release it.
