Nothing too special, just an alternative facade of colors.
On ‎7‎/‎11‎/‎2016 at 3:30 PM, TheOrcKing said:
Nice. Where did u get the shelves?
Re-Haunted House by Tim
You would need to ask the builder for that. :pardon:
16 minutes ago, TheOrcKing said:
Intresting use of those book elements as tiles there
