i want to know how they got the car on the 2nd floor
Duh.  It's LEGO.  They just brought the bricks upstairs and built it there.  Geez...
:lol:
Tower Heist
22 minutes ago, TheOrcKing said:
Is that a drive-up window at the post office? I've never seen anything like that, in my life.
Nope, that's where they load the mail into the mail van.
