On ‎7‎/‎30‎/‎2016 at 3:25 AM, TheOrcKing said:
Detroit 2016 :(
On ‎8‎/‎19‎/‎2016 at 8:06 AM, TheOrcKing said:
Oh!  Well.  Hmm...wonder what that looks like next to a haunted house?
Don't give TLG any ideas. No one wants any Haunted themes for awhile. [emoji6]
Speak for yourself. I'll take monster themes as an evergreen theme. :lol:
I'm banking on the idea that others will as well. [emoji6]
