On ‎7‎/‎22‎/‎2016 at 3:14 PM, TheOrcKing said:
Now I see why those brick separators are on the top sellers list.
I was watching LEGO Star Wars The Freemaker Adventures this morning, and caught a bunch of brick separators in the background, as decorations for a hanger bay.  Probably not decorations, but, they were integrated into the wall "seamlessly" but it was obvious what they were.
Bought this book today, great for tips and ideas on how to build some cool iconic landmarks!
5 hours ago, TheGallows said:
winter_castle_078
This pic is going to cost me some money now, and some how find more display place
