5 hours ago, TheOrcKing said:
What's not to like about this MOC? Wonderful. I particularly like the curved wall made out of white macaroni bricks - looks great both from the inside as well as from the outside. I'd want this building for my city!
It is impressive on a number of levels.
Doesn't meet fire code .. no stairway. ;)
The only issue I see with the macaroni brick wall is that it wouldn't be good for someone with OCD .. how do you make sure they are all perfectly lined up?! But otherwise, it looks great.
You're Canadian, so I forgive you, but it's not ADA, either.  No elevator for access.
What'd'ya mean? There's a big white elevator shaft running the entire height of the building ...
I was coming back to point out that very same thing. There are also no front steps (door at ground level) which is very accessible...
:P
:P
Umm...
I just run the mop here.  Carry on. :lol:
