over compensating
38 minutes ago, marcandre said:
What would you call this?
A level in Rampage.
On ‎5‎/‎10‎/‎2016 at 8:51 AM, TheGallows said:
Stunning!
I really want that library
20 minutes ago, TheOrcKing said:
I like this and the other station you posted. I suppose at some point Lego will release a train station in modular form, here's to hoping its sooner rather than later.
I posted this in projects picks a few months back, but the truth of the matter is this would never get pass the approvel stage.
I've seen some of your guys modular towns so I'm going post it here too I think it would make and excellent , I would love to build something like this. Loads of detail, actually looks like lego have designed it.
2284789-o_1a9rsuhtlp081a5ne9pm3d1i517-fu2284792-o_1a9rsvj4c122b1tgbrj913j412kac-2284795-o_1a9rsvr1e14t5rlr4aken0rdih-ful2284798-o_1a9rt02k41peo7ovh7p16jtgl3m-fu2284801-o_1a9rt09lgttvmqpmsr1ul21666r-fu2284804-o_1a9rt0gn31kgb1m851jf11boeskk102284816-o_1a9rt1mns1gq7lfgmrg1edf1qul1k-2284822-o_1a9rt26prabjk4fni817lo1q2u1u-f2284825-o_1a9rt2i24upi1hmvb6096r1ul023-f2284831-o_1a9rt3aque1h1di9nfnv91gat2d-fu
That last mini-build really needs the plank from the carpenter CMF.
Not sure what that makes me for thinking of it, doubt it’s good.
