Nice building. Terrible name for a food joint...
Those are good burgers Walter
On ‎4‎/‎2‎/‎2016 at 1:28 AM, TheOrcKing said:
Santa forgot to set one of his clocks back from DST though .....
I like the parking meters [emoji4]
What are you a meter maid...?
No a meter eater
5 minutes ago, Phil B said:
No a meter eater
I see it in the smile now...
