I love the bank-robbery scene but the Town Hall mod looks awful with its weird arrangement of windows, interrupted friezes and split tower.
18 minutes ago, TheOrcKing said:
This is one of my favorite MOC/MOD projects I've seen and may eventually attempt myself. My OCD-ness likes how it preserves the original modular set and expands on it to convert it to a true standalone building that could be displayed at the end of a street scene with a fountain or park in front.
13 hours ago, TheOrcKing said:
If the MOCPages image links above are slow or down then try Brickshelf.
Having never set foot in a White Castle before - is it company policy for employees to shave their heads bald?
All that MOC is missing is these two:
And a toilet.
