Jack & Coke please...
21 hours ago, TheOrcKing said:
this one made me think the Green Grocer and Cafe Corner had a kid and were trying to make it grow up like a Parisian Restaurant
On January 26, 2016 at 9:14 PM, brickcrazyhouse said:
Love these 2! I think I might have to try out making a giant palace cinema :)
Look at first picture, plus would be nice (and possible) if those light beams really worked :rock:
Wow, they still have 41999, $200?
21 hours ago, brickcrazyhouse said:
must be Mark trying to move all those sets
I have one left. Best time for them is long gone I'm afraid. They were selling for near $500 on eBay once LEGO Shop at Home sold out but local stores still had them. Now they're little over $300.
1 hour ago, TheGallows said:
Man, I really want that!
The burger joint next to the funeral home is a little creepy.
