Advanced building techniques & questions
  • Replies 166
  • Views 99.6k
  • Great technique, gives an excellent effect.
  • Have a gander at these artistic lamps using a number of new elements introduced with Nexo Knights then read over the rest on New Elementary.
  • Here is an album filled with all sorts of stair examples cause, you know, houses need stairs. Ha.
Wow, great link Efonsecab! The only other place that I can think of is the LEGO Master Builders Academy, which I am pretty sure that you have heard of.
Great write-up, although the English is a little broken.  There is a wealth of information for fledgling MOCers, including the brick ratios that drive advanced building techniques.
I find the best way to find techniques is to check out other MOCers Flikr pages and look to see what they've done.  This is especially true for Technic, where you're combining brick construction with axle and gear construction.  Eurobricks has a lot of MOCs posted, and many times the builder MOCer will answer questions about their build techniques in the forum post.
Thanks, yes I have heard of Master Builders Academy, I think the program is not available in my country tho.
Unfortunately, it isn't for some reason. Sorry about that.
Excellent read, thank you efonsecab  :thumbsup:
Anyone else have anything like this around?
The Lego channel on Youtube recently did a series of about a dozen videos on specific techniques. They're just 2 minute tutorials done by Lego designers, but they're fun.
Excellent, I will look for them, thanks.
Here are a few videos from the Lego channel to get things started.
Panel Building
http://www.youtube.com/watch?v=bs2AYCI2Mnw
Combo Car: Highway Speedster & Mini Skyflyer
http://www.youtube.com/watch?v=cA4Evk5JDC0
Display Stand
http://www.youtube.com/watch?v=QM3SG_EZdXo
Windows
http://www.youtube.com/watch?v=t1vGS6Xs1rc
Building Details
http://www.youtube.com/watch?v=9o2W76Q-C4E
Sliding Doors
http://www.youtube.com/watch?v=4E1oFMRX9J8
the official lego vids are good too
Moving right along with some more Designer videos.
Angled Walls
http://www.youtube.com/watch?v=7jOVIpZj1g8
Corner Door
http://www.youtube.com/watch?v=eMsAGB4xWqQ
Columns - Part 1
http://www.youtube.com/watch?v=-UKh3YrTsZE
Columns - Part 2
http://www.youtube.com/watch?v=x8PMS8gW9d4
Designing Cars
http://www.youtube.com/watch?v=sANW7bzH6Ig
Buggy
http://www.youtube.com/watch?v=1tE96eqnslI
  • 3 months later...
Sorry for the major necropost here, but I thought some people might be interested in the Eurobricks guide to building medieval villages (by Derfel Cadarn). Been wanting to share this for months now, I guess this is the right place:
http://www.eurobricks.com/forum/index.php?showtopic=60907
You also might want to check out his flickr for more inspiration (he is absolutely amazing - definitely one of my favorite MOCers!) http://www.flickr.com/photos/45244184@N04/
Eurobricks is your friend if you are interested in picking up some MOCing techniques and viewing and chatting with other MOCers.
Thanks for resurrecting this one - I've passed it along to Mr. Frog to peruse. ;-)
As someone that can't build crap without instructions, that guy, to me, is simply amazing.  I have followed his medieval village guide a few times just to watch the whole thing unfold and am amazed every time.
There is a LEGO Techniques group on Flickr with some great ideas.
Someone on Eurobricks posted a Powerpoint on doing landscapes that I found helpful.
I agree with others about the Medieval Village guide by Derfel Cadarn, the guy does amazing work.
Also, the Lego Ideas books are very good for inspiration and techniques. The books are available on Amazon at a discount or check in a local library.
Brick Journal is also full of building techniques. The latest issue shows lots of castle building.
His ships are amazing.  I especially like the Crimson Wolf.
My Lego store sells them I think. Pretty pricey, are they worth it?
I wish I was creative.
  • 4 months later...
I figured we could use an all-around thread for those random "How do I build this?" sorts of questions starting with one from me. Can anyone figure out how these pinball machines were built? I can't tell what the playfield box is sitting on for legs.
Keep Those Balls Rolling!>Keep Those Balls Rolling! by Dave Shaddix, on Flickr
Nice thread.
I guess it is using windows.
I think you will need the following bricks:
1x 60592
1x 60593
4x 3024 (around the 2377)
1x 3069
1x 2412
1x 3937
1x 3938
For the bottom, it's to hard to say (6x 6141 of course but the rest... ?)
With a 2362 under the 60593 and a 3022 to stick them, and some plate tiles under, maybe it's ok.
Or maybe this way (feet upside down):
Something that disturbs me is that the horizontal  window seems to be a 1x2x4 on the picture (I virtually used a 1x2x3)... it should explain why it seems that there are two plots large between the 6141 plots (and not just one, as I showed with a blue 1x2 plate tile)
Merci, biniou. What you have put together looks very close to the source. I think the horizontal window is a 1x2x3 as I don't think there is a 1x2x4 or I just can't find it. Anyway, I managed to come up with an idea that takes inspiration from this and another design I came across on eBay of all places. The result doesn't have the subtle angle like a real pinball machine does but at least it does look the part.
Because my LDD is not working at the moment, I cannot show you exactally how this works, but I am seeing headlight bricks at the bottom.  The pinball machines will not stick to the ground because the studs are upside down.  The front is only one stud deep and the back is two.
Here is a pattern for the bottom (from front to back):
2X1 grill
2 headlight bricks next to each other
2X1 brick
2 more headlight bricks next to each other
2X2 plate
Put one stud on each of the front headlight bricks and put two studs on each of the back headlight bricks.
The rest should be easy to figure out.
2X1 grill
2X1 brick
2X2 plate
Awesome, I think you're right ! And that explains why it seems there's a larger space between the studs.
A less clownish version:
It needs some stickers. :zorro:
