November 27, 20178 yr I can't find part numbers and can't figure out the descriptor that unlocks these pieces.
November 27, 20178 yr I can't find part numbers and can't figure out the descriptor that unlocks these pieces. The green pieces (6043 & 6042) are from either 2160 Crystal Scavenger or 2162 Hydro Reef Wrecker from 1997.
November 28, 20178 yr On 26/11/2017 at 11:13 PM, thoroakenfelder said: I can't find part numbers and can't figure out the descriptor that unlocks these pieces. 30198 - Minifig, Utensil Grab Jaw Holder 4221 - Arm Grab Jaw 6032 - Brick, Modified Octagonal 2 x 3 x 1 2/3 Sloped 6043 - Brick, Modified Octagonal 2 x 2 x 3 1/3 Corner x107 - Minifig, Headgear Hat, High Cone Shaped x514c01 - Technic Rotation Joint Ball with Arm - Pin and Hole Ends
June 2, 20187 yr I need help identifying these sets based on the parts visible. Any help is much appreciated.
June 2, 20187 yr 2 hours ago, labfreak7 said: I need help identifying these sets based on the parts visible. Any help is much appreciated. grievous starfighter, tie defender, hagrids hut
June 4, 20187 yr Anybody know anything about this brick? Part number? Set(s) it comes from? Etc. It has an uppercase ‘F’ number ‘5’ and the words pat. pend. on it. Which I’m guessing is short for patent pending
June 4, 20187 yr 6 minutes ago, stuco191 said: Anybody know anything about this brick? Part number? Set(s) it comes from? Etc. It has an uppercase ‘F’ number ‘5’ and the words pat. pend. on it. Which I’m guessing is short for patent pending Just your standard wheel holder - 1959-1996 available in 100+ sets Bricklink part # 7049b (Brick, Modified 2 x 4 with Wheels Holder Old and Trans-Clear Bottom)
June 4, 20187 yr Just your standard wheel holder - 1959-1996 available in 100+ sets Bricklink part # 7049b (Brick, Modified 2 x 4 with Wheels Holder Old and Trans-Clear Bottom)Wow thx! Appreciate it
