August 2, 201510 yr Hi. Do you know if LEGO train track and/or 7938 passenger train or Ghost train will fit through the gateway of Vampyre Castle? (Width and height).Just thinking about it for a MOC so anyone with knowledge would be appreciated.Thanks
August 2, 201510 yr Another member on here did something similar to that a while back, you may want to search through the forums a bit.
August 3, 201510 yr Solution Another member on here did something similar to that a while back, you may want to search through the forums a bit. I think that was for the silver mine review. That was well done! Hi. Do you know if LEGO train track and/or 7938 passenger train or Ghost train will fit through the gateway of Vampyre Castle? (Width and height). Just thinking about it for a MOC so anyone with knowledge would be appreciated. Thanks it won't fit without modification, the gate's entrance is 7 studs wide and about 7 studs tall at the lowest part of the arch. Lego track is 8 studs wide.
August 3, 201510 yr No, there was another one that did vampire castle, but dropped it before he could do pics
Thanks
