Brickfolio and Price Guide FAQs (Site Update)
To Brickpicker admin. Your listing for http://www.brickpicker.com/bpms/set.cfm?set=375-2 has a used price of $60 for this set, while the Ebay listings are in the $200-$300 range. Why the difference?
  • Replies 1.2k
  • Views 372.1k
  • Thread is locked. Any new threads will be locked.  Please do not message me for your data.  All the data is safe, backed up multiple times over. Brickfolio will be available this year.  I am working o
  • Ok here is an update.  Things have changed on how we get our data and the format that it is in.  It seems that everyone in all the major companies are really either closing doors on data that is given
  • Jeff Mack
    Jeff Mack
    A lot will be coming in the coming weeks.  Both of us have been pretty quiet lately. Getting away from the book, regular work has just been non-stop, but now I am moving into working towards an overha
Me too. Will check again tomorrow.
Ehm... Mr. Mack. You killed my brickfolio :)
post-33870-0-65752400-1428445319_thumb.j
yeah i got about the same screen as Neosphinx and the Select Data Set Currency always revert back to Dollars after i try to set it to AUD. it does still says update successful and will reload the window but when i checked it does nothing but back to USD.
You just got this right now or much earlier? You went in and set the values, hit save so that it stores the values in the database?
 Mine is working again. Thanks!
Ok, good, just need to see if its an issue still for others.  Please just make sure that anyone goes to the brickfolio dashboard, hit the button to change the currency and data currency and hit save.
No issues here, seems to work perfectly.
Hi
I read in a forum topic that it should be possible to import sets from Brickset into Brickfolio.
Is this option still available??   I looked in the Brickfolio data services part, but don't see anything like that.
Cheers
Ludo
If you already have items in your brickfolio the option disappears. Brickfolio 2.0 is under development and will finally have true synching services.
Hi Jeff, mine is working again. But as mentioned before i encounter the same problem as Neosphinx and also the change of currency. i did click save and reload window but to no effect
Anyway all sorted. Thanks!
Hi Jeff,
Apparently it was not resolved to certain extent. The change of currency is okie now, but when i wanted to add some new sets to my brickfolio, i encountered the currency for the Purchase Price set to USD? but on the brickfolio dashboard all is okie with the currency set to AUD for my region.
Have not come across these problems before since i join Brickpicker some time ago.
Something wrong with the server?
I've entered a couple of sets today which showed as no value, Milano Spaceship Rescue and Agents Mission HQ. Is this just because there's not enough sales data to provide a price, or it just a bug on those sets?
Another useful feature of the brickfolio is provide a column for percentage change for the past month so that you get an idea if the set is trending up or down without having to click on the set data.
It appears the brickfolio is being updated today...
My question:  Why is there such a discrepancy in value between the Dashboard value and value shown at the bottom of the "view entire collection" page?
Thank you for any responses.
Does anyone have insight on why my Brickfolio homepage would show one value but when on the "view entire list" page.
I can't seem to get rid of the ali...bad page express either
I also have 2 different values on the dashboard page and view all page. Tried changing dataset back to US $ and then back to Euro but remains similar. On the plus side, the brickfolio stays on Euro data-set
I had it happen as well a few days ago. Also anyone notice a change in brickfolio values in the last few days, then a reversion back to earlier value today. Odd?
Any idea on the change in Brickfolio values in the last week?  An update that was stopped, reversed?
I have not run the update yet.  I am still waiting on one day from the vendor so that I can start it.  Did you notice the change in values while I was trying to fix the currency issue from not holding a few days back.  Perhaps you caught saw the inconsistency while i was working on that?
Maybe that was it.  Portfolio in dollars moved up about 5% over Feb numbers.
The way I read you post was that it sounded like it changed but then went back.  Is it still 5%+ or did it revert back to where it was before?
There were new numbers in the Brickfolio a couple days ago but has since reverted back to February $'s.  I assume that is what he is talking about as I noticed it as well and assumed the March #'s were out.
Yes, this is what happened.  It has reverted back to the feb numbers that were in there already.
Jeff, re earlier email, I can now access the forums but not brickfolio, it doesn't recognise my password when I go to my brickfolio.
Update: I can only log in via the new password link via gmail in my instance. I cannot log in via the browser, Safari in my instance. Getting weirder!
Edited by doon73
Jeff, re earlier email, I can access the forums but not brickfolio, it doesn't recognise my password when I go to my brickfolio.
​I have you logged out and back in today?  Also try clearing your cookies.  I updated this earlier today and seems like a lot of people are making updates, so it seems to be working.
